1 - 10 of 10 Posts
The bike ran fine. I pull into garage and lower the sidestand with bike in gear and clutch in. Engine stops. I tell myself to remember this in the future. I'm a new rider and have owned the bike for 2 weeks. Anyway, next morning the bike won't start. Bike is in neutral, engine stop switch is set to run and nothing. The lights come on bright and horn is normal. When trying to start there are no clicks. I tried checking for voltage from the starter relay when the starter button is pushed. No dice. Has this happened to anyone? I think it is one of the safety switches like on the clutch or sidestand. Because there is no power going to the starter relay, does this mean that I can not get it rolling and pop it into 2nd? Do the safety switches kill the engine totally? If no one has a fix, I have an appointment on Friday but hoped I could get it started by method above instead of renting U-Haul. I have swapped the fuse for the ignition and I have unplugged the saftey switches for both the sidestand and clutch to complete the circuit with a paperclip. Any help is appreciated.
Doh!! Forgot the title of the post. sorry :oops: This might not help but I'll share with you what my old bike, a '00 Katana 600, used to do. Just to let you know I always turned off the bike with the kill switch. I found that sometimes after repeated starting fail attempts, the order in which I did things had an effect. I have no idea why. I found that I had to sit on the bike with the kickstand down. Hold the clutch in, then flip the kill switch to run. Then the bike would start. If the switch was already in run and I held the clutch, nothing would happen. My ride would accept a pop start, and I don't think it's harmful expect if the engine were cold. I doubt this'll have any relevancy or help at all. Just an idea. You seem to be scratching your head pretty good on this one.
If all else fails and you can't figure out what's wrong, find a buddy who knows bike and maybe he'll offer another perspective. Or just take it to a mechanic. Since it's a 2002 I doubt the warranty will still be in effect. Unless you traded it over to you when you bought it and got the extended warranty.
Sorry for the long response.
Discussion Starter · #8 ·
Being a new rider I too had a routine to start by bike. Bike in neutral, kill switch to run and hit starter button with chock set so that idle was at 3000. In 3-5 minutes it would be at 4000 and I would turn chco off and the bike was ready. Tomorrow I will get it moving and pop it in 2nd to see if the engine will start. The result may shed some light on the problem.
Do you routinely turn the kill switch to off when you have turned the bike off? Try bump starting it in second, if it won't turn over at all then the kill switch is faulty if it does then immediately cuts out then it could be the sidestand cut off sensor.
Discussion Starter · #10 ·
Ok. This is the last ditch effort. The closest bike shop wants a minimum of $140 to diagnose the bike. That will be applied to the total cost. I have no voltage going into the starter relay. In the service manual it lists the eight causes as:
· Faulty ignition switch
· Faulty engine stop switch
· Faulty clutch lever position switch
· Faulty neutral switch
· Faulty turn signal/side-stand relay
· Faulty started button
· Poor contact of connection
· Open circuit in wire harness
The starter button and engine stop switch are one unit. Someone told me to disconnect the engine stop switch to see if the bike would start but since they're connected it kills the starter switch. If I disconnect this and push start should it start with ignition on? It won't with it connected. One of those eight are breaking the current. Any help would be great. I have my permit, passed the MSF so license will be hand soon. This will the last week I will mess with this.
1 - 10 of 10 Posts
