i replaced the rear brake pads on my 05 boulevard and brakes wont bleed. first I wasnt aware you could just remove the top cover and simply slide the pads out the top...I know now. I removed the back half of calipar and removed that pad. when i pressed the calipar sleeve to make room for new pads..the fluid squirted out a small hole close to the bleeder valve. i saw no gaskets or o rings anywhere/ when i reassembeled the calipar I cant get the brakes to pump up...very little pressure. fluid will come out the bleeder but been at it for a while and still no pressure..I know all is assembeled correct..wasnt that hard..but still no rear brakes.....help please...
