07 Boulevard M50..sat for about 1 yr. parked it with a full tank to prevent tank corrosion. Battery went bad so i bought new, good battery. tried to start and it only cranks, no fire. starting fluid will let it run for a sec. i can hear the pump run in tank. pulled tank off and had gas in the line. pulled injector and gave it 12 volts, it opened and i can blow through it. any ideas on what and how to test?
Test the pump for flow and pressure.
Likely it has failed......or the screen in the tank is plugged up.
I think I have a similar problem with my 2009 M50SE, but I left the bike in storage for 4 years. I had tried to start it a few times in the past few years and even bought a new battery without any success. Initially, I thought that the tank was rusted because there was a rough brown residue, that I could feel, inside the filler cap. With that, I figured the tank was rusted and the bike ruined. Last fall, I removed and drained the tank and then removed the fuel pump to let everything dry out over the winter. I just went back and looked. Where the gas had evaporated, there was the same brown residue that was easy to flake-off. The residue must have been from the gas and it all came off when I brushed it with a stiff nylon brush. There did not appear to be any dirt on the filter as it was just a tan color, but I am going to buy a fuel pump kit and replace it.
I have kind of lost interest in riding and just want to sell it to close the storage unit. Any thoughts on my next steps would be appreciated. Thanks.
Get it running and sell it. The residue is likely from the fuel additives that you have over there and is easily removed. A good doese of fuel system cleaner will probably take care of any other possible fuel related problems than put it up for sale....I guess
