Hi all,
I bought a 1978 GS550 in August of last year and its had quite a few problems that I can not seem to diagnose with my skill level. I like to start the bike every week or so when im not riding during the winter but this time it will not start. Granted it 20 degrees right now in Columbus but I got it to start in similar weather a week ago. It will crank and then run for a solid 5 seconds before dying on me. When its 70 degrees or hotter i have to hold the choke open for a solid minute or two just to get the thing to idle and then it runs well but if you drop the choke before then it dies. It seems like its just getting a serious lack of fuel or something. This is besides the fact that after some idiot kicked my bike and broke a plug the plug that i replaced fouled in less than a month with me barely riding the thing. The problem last time i started it was a fouled plug on cylinder 1 (the one closest to the kickstand) as well as all of the carburetors having a bunch of orange garbage leak out of them when i unscrewed the drain screw at the bottom of each carb. After that it started right up. I tried the same solution except replacing the plug and it still does not want to start and im worried im gonna kill the battery or the starter and kick starting is definitely out of the question. I am very inexperienced with carburetors as im only 21 and all of my cars have been EFI. The plug on cylinder 1 is a glossy black now and im assuming there is something seriously wrong with the bike at this point because it believe it to be oil fouling. Is there a possibility that the fuel is bad? I regularly use a Carb Defender additive in the fuel because i believe the fuel lines are original and i dont want the ethanol in the gas to burn through them or the parts in the engine. Sorry for the long post any ideas on what could be wrong are greatly appreciated!
Thanks,
Joe
Thanks,
Joe
