fire_fighter_mike2 said:
The battery is bad and will only hold a charge for a couple of minutes before dieing. But wouldn't the horn or starter make a sound?
Points, what exactly are those?
Thansk
You shoulda said this earlier. If your battery *is* charged, but wont hold a charge, then your starter will not work. When my bike killed its battery, only the headlight worked. The starter draws a ton of power. And no, you won't have a horn either, becuz that only works when the ignition is on, and since you've got a dead battery already struggling to run a headlight and the instrument lights, you don't have enough juice for the horn.
So, get a battery, and make sure the store charges it for you. Batteries are not shipped with acid in them, nor are they charged. When you buy the battery, tell them you want it charged. It shouldn't cost anymore (didnt for me), and they'll keep the battery overnight, fill it with acid, and charge it for you.
I'm not absolutely positive, but I don't think your bike has points. "Points" are what old vehicles use to jump the ignition spark down the wire and across the spark plug electrode. It's really hard to describe without a picture, so do a google search on "points ignition systems" and you should find several good tutorials. Besides, with a bike with as few miles as yours, even though it's old, your ignition system is fine with the possible exception of spark plugs. My GS450 has 15k miles on it, and it's in great condition electrically and mechanically.
Oh, and here's a very helpful tip for you: DO NOT leave the headlight switched on all the time. When it's left on, that means that, every time you put the key in the ignition, the headlight is on for a few seconds before you start the engine. That headlight is drawing power (a lot of power) directly from the battery without the generator to recharge it. The same thing applies to when you're parking the bike. Turn the headlight off BEFORE you shut the engine off. Otherwise you'll suck the battery dry in a few weeks becuz the headlight is running without the generator. Make sense?
