Hello, I was wondering if anyone could point me in the direction of where to find the Rectifier/regulator on the 1983 GS650L.
Thank you For your help.
Check under the side covers...usually the lh one when sat on the bike. Alternatively it may be under the seat or belly pan if fitted. Finally many makers began integrating the reg rec into one unit. If this doesnt help check on line for a wiring diagram...this may indicate a position.
