I have a 1988 GSX600F Katana which I cannot seem to work out the carb issues on.
I completely disassembled the carbs, cleaned and reassembled them over the winter. I am absolutely sure there are no parts left out as I did this in a relatively sterile environment with parts carecully laid out and numbered.
When I hooked the carbs back up, they ran good for awhile and I syncronised them using a home made manonmeter setup. I also rode the bike for approx one week and 400 miles with good performance.
I decided to resyncronise them and after removing the airbox, I noticed that two carbs were spouting fuel evertime I turned the stopcock on. I am aware of the vacuum diaphram in the stopcock, mine is damaged so I installed another stopcock in series witht he original.
Here's the nexus question. If you flow fuel to these carbs, do the needle valves in the float chamber stop the flow when the chamber is full or will they continue to spout fuel even though the bowls are full
I also have replaced the vacuum diaphrams on the top of each carb with newer ones, but I set the stops on the needle valves identical to the way they were before.
I assume it will take someone who had been through the same thing with these carbs to accurately answer this.
Maybe they are supposed to leak fuel constantly and thats what the vacuum diaphram in the stopcock is for.
Thanks in advance and I will post any sucesses.
HELPPPPPPPPPPP!!!!!!!!!
UPDATE ---------
I disassembled all the carbs. I set the float height very carefully. I hooked each carb up individually to the gas tank to see if it would leak. None of them did. I reassembled the entire assembly and hooked it up to the fuel tank to check for leakeage. No leakage. I installed the carb assembly back on the bike and hooked it up to the fuel tank, turned on the fuel to check for leakage. No leakage.
I then tried to start the bike. It fired and then quit. Immediately the carbs began leaking gas out the intake side through the small holes on all four carbs. Now when ever I turn on the fuel, all four carbs pour fuel out the small holes on the intake (airbox) side.
I have done everything correctly at least 15 times and this still leaks fuel like a Kuwaiti oil well with Sadamm at the valve. I am stumped like I have never been before. I am so mad I want to burn the bike in the backyard.
Please help I am absolutely stumped!!!!!
Attached is a photo showing the holes (small hole at bottom of intake side)
that are pouring the fuel.
UPDATE ---------
