Hi, recently stripped the airbox from my 1988 suzuki Gsx 550 with the intention of fitting air pod filters but i am struggling to find any suitable ones to fit the carbs. The carbs are Mikuni BSW30SS 30mm with dual intakes on each side and as of yet i cannot find anything suitable. Diameter is 9 1/2 cm and height is 5cm. Any help is appreciated. Since they are CV carbs im told fitting pods is not ideal but has anyone had any success?
YOu should listen to that advice.
You likely will NOT like how it runs with a low restriction intake.
Have you done a test ride with the intake OFF ??
That would be a pretty good test.
