the timing is fixed and should only need adjustment if the flywheel or stator plate has been removed.there should be an arrow on the the case where the stator bolts to. just make sure you have that aligned with the mark on the stator.and your in buisness.the cd ignition box is what controls the spark timing.hope this helps. ash
