i have the above bike, its low on power, wont idle properly miss now and then , idles strange on side stand, wont idle off choke, and has a rattle above 5,500rpm possible timing chain, have replaced plugs, striped and cleaned carbs, dont know how to sync them so wond mixture screws out 1.5 turns out from all way in, also only does 150km at top speed. any help will be apreciated.
ps whats the valve clearance on these pus buckets. also how major is it to change timing chain, is there a link?, what compressions should i have?, how to sync/set carbs? and ignition timing?, coil ohm readings?, correct plugs?, do i need air box on to ride? its off at mo and runs like poo. also rev counter sticks at 7000rpm how to unstick?
any other info please trial and error
ta
ta
