mixture screw
The adjustment screw for the rear carb is on the right side of the bike, just behind the throttle assembly at the carb. It has an ‘O’-shaped brass plug covering it, so if you want to adjust the screw you will need to use a drill and drill bit to enlarge the hole in the plug to access the screw. Don’t drill too deep, or you’ll damage the screw. Screw a large sheet metal screw into the brass plug as tight as you can, and them pull it off with some pliers, thus removing the plug. You can then adjust the mixture screw underneath it.
