Being new here and not having the service manual yet, I have a headlight problem :( . I only have highbeam on my gixxer. When I looked at the wiring, I found the solid yellow wire to them spliced into a black with brown stripe wire with the other end (nearest to the headlight) of the black with brown stripe wire hanging loose. I think it may have a bad headlight relay and that's why somebody jury-rigged it like it is. If this is true, where is the relay and if not....does anyone have any ideas. Thanks in advance!! :D
get the manual, without it, your down to the guess and check method. which you might end up doing even with the manual. try searching somewhere for a wiring diagram of your bike, cuz without it, it is some confusing ****. good luck.
