rear carb slide bouncing causing.high idle
cbyuma · Registered Joined 17 d ago · 1 Posts Discussion Starter · #1 · 17 d ago Only show this user rear carb slide bouncing causing.high idle
Aussie Steve · Registered Joined Jan 9, 2007 · 7,269 Posts #2 · 17 d ago Only show this user Weak spring....holed diaphragm.
E Easy Rider · Super Moderator Joined Apr 14, 2007 · 13,850 Posts #3 · 16 d ago Only show this user cbyuma said: rear carb slide bouncing causing.high idle Click to expand... Vacuum leak ? Does that carb supply the vacuum to the automatic petcock ?
