I just had the carbs cleaned and rebuilt. All the cables and everything are together. I'm having a issue now. The problem I'm having is this. It idles pretty well. When I give it throttle it backfires now and shuts off. I checked the air flow mixture . I checked the linkage. I did notice the exhaust from rear cylinder is now barely heating up unlike the front heats like normal. I am running out of options of what will get this to stop. What can I do to get my bike running
When you are out of ideas, you probably need professional help.......onsite.
Does it run better with the choke partially ON ?
Better if you let it idle long enough to warm up ?
How exactly did you "check the air flow mixture" ?
Are you testing with stock pipes and air filter in place ??
