HELLO GUYS! I’m MATT! JUST PURCHASED MY FORST BIKE AND AM IN THE MIDDLE OF MAKING THIS THING SHINE AGAIN
HAVING A REAL ROUGH TIME, MY TAIL LIGHT (LED) AND MY TURN SIGNAL LIGHTS (LED) ARE VERY DIM. DONT KNOW WHAT TO DO, WHEN I HAVE THEM DIRECTLY HOOKED UP THE THE POWER PROB THEY ARE BRIGHT AS THEY SHOULD BE. THE TAIL LIGHT HAS A PLUG IN PLAY CONNECTOR WITH 2 ADDITIONAL WIRES FOR TURN SIGNALS. I AM AT A LOSS, BRAKE LIGHT (AND RUNNING LIGHT) AND SIGNALS ARE SO DIM WHEN YOU ARE DRIVING YOU CAN BARLEY SEE THE LIGHT. I SEEN ANOTHER POST ABOUT THIS A WHILE BACK BUT NO REAL ANSWERS.. PLEASE HELP!!
ground is good, checked with power prob.
What exactly does that mean ?
If the lights don't work, then there IS a problem getting power to them OR a problem with not having a good negative ground connection. Unless the lights themselves are defective, those are the only two possible causes.
Seems you have a heavy resistance in the connector or circuit....unless that is where you connected the direct power to...I am assuming this is what you mean by power prob
