some one please help me what is problem with 2000 gsxr600 . some time start some time not, when bike stared is run fine, when I shut off, and won't start back up. light , horn, fuel pump is working, i changed new battery, Push to start is start, when it not start leave it for over night then start right up.check killer switch is ok.electric start switch is good , but have no power , any Idea I need to replace..this is second bike that I have same problem.
Thank for you time
· Site Admin & Squeegee Boy
Having a hard time reading your post.
New battery ok, power to some electricals yet you say no power.
When you say it doesn't start are you meaning that the starter isn't operating or the starter is working and the engine is turning over but doesn't fire ?
And here's a wild guess! Are you sometimes trying to start it in gear with the kickstand down other times with the kickstand up and/or in neutral ?.
Won't start with the clutch out either. :wink:
I know this is obvious but it could be a dodgy connection or a dodgy switch.Like Uncle Bob says,could also be to do with stand switch.
I had a 2000 Katana 600 that had a similar problem. Sometimes it would start and sometimes not. I figured out that I had to do a certain "routine" to get it running. First sit on it and retract the kickstand, then hold in the clutch, flip the kill switch to run, then press the go button. If I flipped the kill switch to run then held in the clutch, I got nowhere. Don't know why, but that what I did with my bike. Maybe yours had a funky personality like mine did.
