1 - 20 of 20 Posts
Hey guys, I ran into a problem yesterday with my 2002 1500 Intruder LC not starting. It's been starting great even through cold weather. When I hit the start button it does absolutely nothing? I had the battery checked and its good. Lights, horn and everything else work just fine. Only problem the bike won't turn over. Nothing dims when I hit the start switch. I've cleaned the kill switch and the clutch safety switch, still nothing. Some guys on another forum suggested it might be the decomp out of adjustment. Only thing with that wouldn't it turn over a little if that were the problem? Anyway I'm getting a little flustered here and if anyone could shed some light or have had this happen to them I'd appreciate you letting me know what you found to be the problem....Thanks
Jim
Intruder 1500LCs from this time period are notorious for this sort of starting problem. The bike acts liek the battery is dead, or the battery will drain suddenly, or the bike will turn over but not spark. Sometimes you can jump start the bike and it will fire right up, sometimes if you just let it sit it will fire right up, other times no matter what you do it will not start. These electrical demons have driven more than one Intruder 1500LC owner bonkers, and have trashed the reputation of an otherwise fine bike.
It all stems from a very poorly designed stator/ signal generator/ wire harness assembly, and I have seen dozens of 1998-2004s need this assembly replaced. Suzuki completely redesigned the assembly in 2005 to solve the problem, so they know darn well the original one was flawed- but because it was never a safety issue, they did not have to recall the bikes and fix them for free. So repairs come out of your pocket. You can get a Suzuki OEM assembly for about $330 (the original flawed one is no longer available, so the redesigned model is the only one they sell) or an aftermarket one for about $180. Not hard to put in at all: drain the oil, take off the left side cover, undo three bolts to remove the old one, slip on the new one, feed the wire harness the same way as the old one and plug it into the main harness, put the cover on with a new gasket, refill the oil. The Clymer and Suzuki shop manuals say you need a special tool to remove the old one, but that is because it is so easy to damage the old one, obviously of no concern if you are tossing it in the trash and putting on a new one. If you do not want to tackle it yourself a shop will charge you $150 or so to put it on.
The problem often comes and goes, so the bike may suddenly fire right up, making you think the problem is solved, only to reappear days or weeks later. Eventually the bike will not start no matter what you do until you replace this assembly. So even if your's is not bad right now (though I am 90% sure it is) you might want to go ahead and replace it, because it is going to fail eventually. Solve this one problem and the Intruder 1500LC is a darn fine bike that will last you for 100,000 miles.
Go to this site and read about the decom issues: Decomp Valve Adjustment
This is good to do, and it may solve your problem, though I doubt it. As you say, an out of adjustment decomp cam usually leads to labored cranking, not sudden and total failure to start.
Make sure you check the neutral safety switch also. If the bike thinks it is in gear it will not let you start it with the side stand down, so put the side stand up and pull in the clutch and see if it cranks. But failing something simple like a dead battery or loose connection, your 1500LC probably needs the new stator assembly.
Thank you for the in depth reply. I wasn't expecting to hear it might need a new wire harness assembly. Is it possible it could be something as simple as a starter relay? Is there any way to check it and see if it's bad or could the ignition switch mimic these symptoms?
No, you do not need a wire harness, which is for the whole bike. What I am talking about it the assembly that is comprised of the stator + the signal generator + the wire harness for those parts only. It will most likely fail eventually, so keep it in mind even if that is not the problem this time. Probably 75% of the people I personally know who own or have owned a pre-2005 1500LC have had this assembly fail on them.
By all means check the starter relay- use your multimeter to make sure you are getting power to it, and to check the continuity. There should be continuity between the two big terminals when you hit the starter button (key on, clutch in) and none when it is just sitting there. Some folks like to just cross the two big terminals with a couple of screwdrivers, just like you would jump a starter solenoid on a car. The problem is that jumping it like this bypasses, well, everything, so unless the starter is fried or the battery is dead, the bike will turn over. If the bike starts (key on, tanny in neutral) by jumping the terminals then it does not tell you if the relay itself is bad, or the safety switches, or the starter button, or the wiring, or...well, you see my point. But if you jump this and the bike turns over but does not fire, then you do narrow it down to the CGI box (highly unlikely) or the signal generator/ stator/ harness assembly (likely). Or you may find that you jump the relay like this and the bike fires, and then works normally...at least until at some random time in the future when it won't start again, which is also behavior that is typical of the failing stator/ signal generator assembly.
When the ignition switch fails, generally nothing works, just like the key is off. So if you turn the key on and the headlight comes on, then the ignition switch is most likely OK.
I raised the kickstand, put the bike in neutral, hit the starter switch and it fired right up. I'm not exactly sure why it did but it did. I think you're right, it'll most likely not start on me again sometime. Thing is your never in your own driveway when it decides it doesn't want to start. I'm sure I'll need to replace the stator at some point. I've read where that's a weak point on these bikes. Thank you for your help, it's much appreciated.
Jim
No worries. If you get stuck somewhere, a lot of the time a jump start will cause the bike to start and get you home- the extra juice seems to work sometimes to overcome the problem. Best to replace that stator assembly when budget allows, rather than after you get stuck.
When this problem first started popping up around 2000 or 2001, it drove a LOT of people nuts trying to figure out what the heck was going on, especially as they rarely fail completely all at once, and you get the 'usually it starts, but sometimes it does not' thing going on: you could test the darn thing and it would come back good 99 times out of 100, so mechanics spent a lot of time looking for a problem in other areas. Suzuki dealerships were getting a lot of heat about it. Suzuki finally redesigned the stator assembly to fix it once and for all, and I have never seen the new generation stator fail, even on high mileage bikes, and on bikes that chewed up one or even two of the original part assembly. So it is a true permanent fix if you swap it for the new one, or the aftermarket one.
Other than the stator assembly issue on the pre-2005 bikes, the 1500 is a great bike.
Discussion Starter · #7 ·
"Other than the stator assembly issue on the pre-2005 bikes, the 1500 is a great bike."
Yes it is. I haven't had a single minutes trouble out of it since I bought it and am surprised to learn of the stator assembly issues. The last bike I owned supposedly had stator problems also. Seems like some of these manufacturers can't quite get all the bugs out. Oh well, small price to pay for years of good comfortable riding.
There was a recall on the fuel tanks in 2004 or so, but that is the only other issue I am aware of with that model. A good, solid design, and it is easy to do some simple mods and get a lot more power out of them also.
I had exactly the same problem. Bike would not start. I read all the forums describing stator issues and decomp issues. After messing around a little more I discovered that I could get it to start while holding the ignition switch and messing with the clutch lever. Turned out it was only the clutch switch, I jumpered the switch and it starts every time. Returned the stator and rectifier and saved myself $280.
Help! Suzuki Intruder 1400 1987 won't start. while it was raining the bike shut down at a stop light. the bike would turn over after that but not fire up at all. Then the bike stopped turning over. The lights go on. I've checked that power is going to the main fuses under the left cover.
It would be MUCH better to start your own thread, since this one is several months old and it appears that you might have some unique circumstances.
At this point, you have drained the battery with the crank but no start attempts.......so the first thing to do it charge up the battery.
By the time you get that done, whatever got wet MIGHT have dried out so that it starts now. Let's hope.
Vl 1500 Starter Fix
Jim
I had the same problem with my 2000 Vl1500lc Intruder.The Rear decompression Valve was not opening and after i adjusted it Works Perfectly. There is a video on Youtube that shows what to do. The cable to the rear decomp valve should be taught but still closed after adjustments are made.This is a common issue that Suzuki Dealers say i have no idea what it could be.We will need to look at it. $$$$$.It takes about 1.5 hrs to repair but it is very simple.
Same problem. Last year (2020) the bike died at a gas station after I fueled up. No power to anything. Trailered it to a shop. Month and a half later, they told me it was the clutch switch, which they replaced. Ran fine after that. Until last week (May 2021). Same issue. Dead battery. Something draining it? Checked all the fuses for power with the key off. Nothing. I'd switched headlight bulbs, so I checked the wiring and so on in the headlight shell. All good. I replaced the stator assembly last year with an aftermarket, so that "should" be OK. Ordered a starter relay (less than $10) and I'll jumper the clutch safety wiring next.
Worst part of all of this is that I can no longer trust this motorcycle.....
"it should be OK" is not a valid assumption.
You need to test the charging voltage.....and the main battery connections.
And by now, you might need a new battery.
Then.....you replacing the stator might be a clue that you are running accessories that keep the battery from charging fully even when riding.
If you don't take at least one nice long ride every week, then a battery tender might be a good idea too.
No mechanical device is perfect.
I don't think I would be so disappointed with two failures a year apart (assuming the time frame).
I'm not running any accessories, bike is totally stock. When I turned key, I get lights, etc. I hit the start and everything - and I mean everything - dies instantly. Then it won't light up at all until I recharge the battery. Battery was on a tender all winter and checked out back in the bike. No sparks or smoke anywhere when I try to start it. Last year, the shop said it was the clutch safety switch that was bad and replaced it. Maybe a starter solenoid? For less than $20, I think I'll change it. If that doesn't do it, I suppose it will have to be hauled back in...
Then why did you replace the stator ?
The symptoms you are relating are CLASSIC for a bad main battery connection.
The high starter current "burns" the loose connection open.
Then after it sits a while, it makes connection again.
You can get a decent meter at Harbor Freight for about $8; WalMart for a bit more.
A couple of minutes testing voltages can save you a LOT of time and money.
The bad connection could be inside the battery.
But it appears that you aren't really listening closely.......so good luck with your "guess" method.
A bad starter solenoid will NOT cause the symptoms that you have.
A bad connection AT the solenoid might, because that often is where the power for all the rest of the bike is fed from through the main fuse.
I've checked the battery connections, but not at the solenoid. That'll be next.
I replaced the stator last year because that's what the local shop recommended. Didn't help. Problem was intermittent. Took it to a distant Suzuki dealer, they replaced the clutch switch. Sold me a new battery. Told me it was fixed. Rode maybe 100 miles before winter. Worked fine for about 100 miles this year, with another new battery, just in case. At least the problem is no longer intermittent. I've tried it with the kick stand up, clutch in. Neutral. Not running any accessories. Both shops told me the charging system was working as it should. Fuses aren't blowing. Doesn't leave much but wires and the solenoid.
EVERYTHING is still in play.
You can't fully eliminate anything until the problem is located and solved.
You NEED to get a meter so you can make some simple tests yourself.
Otherwise further discussion is pretty much pointless.
1 - 20 of 20 Posts
