New bike, coding out, guage says F-1. Used the wire loop, it said c-21 (ATS) Replaced the sensor, it is still coding out. Previous owner installed a smog block off kit, K&N, and Cobra pipes. There is no oxygen sensor on the pipes... hmm. Anyone had a issue similar to this? Any help would be appreciated.
Super Dave
Given all the changes that have been made to it.......and maybe some you don't know about........I suggest that it likely is NOT a good project for you. Parts may be hard to find.
Putting it all back to stock might be needed to have a known starting point.
Does it run even though the FI (fault indicator) light is on ??
If yes, and it runs reasonably good maybe you should just ignore the light.
