Help, my 2006 c90 is having some sort of issue. While riding 80-100 kph and give the bike heavy throttle it feels like the clutch slips for a second then grabs and goes, this only happens when cruising then getting heavy into the throttle. Bike works perfect otherwise.
If it feels like the clutch is slipping, it probably IS.
Is there any "slack" adjustment in the clutch mechanism ? If so, maybe that is too tight.
But the likely problem is that after 15 years of use, the clutch is wearing out.
That might be made worse if you (or a previoius owner) have ever put the wrong kind of oil in it......or the wrong kind of additive in the oil.
You probably will eventually need a clutch rebuild.
But if you don't DO the things that make is slip, it might last a long time too.
