1 - 1 of 1 Posts
The engine failed on me at 22,000 miles not worth rebuilding or buying a new motor the bike has never been in a wreck I found out engine failures are quite common on my year so I've decided to part it out I currently have everything but its not taken off the bike yet. If you interested in a part thats not listed please feel free to comment or send me a pm. I have a clean tittle on the frame for anyone thats interested.
Gas Tank - $275.00
Radiator with fan - $215.00
Left faring - $100.00
Left lower faring - $50.00
Rear faring - $115.00 SOLD
Wind screen - $65.00
Headlights - $215.00
Carborn fiber yoshi slip on - $315.00
Gage cluster - $155.00
Left & right turn signal cover $20.00 Each
Seat - $45.00
Rear seat - $25.00
Fuel pump - $70.00
Mirror blockoffs (vortex) - $40.00
Left Rear sets - $45.00
Triple tree -$ 70.00
Forks - $375.00 Have Receipt with recent fork seals done. No more then 500 miles on them.
Front fender fairing - $65.00
Front tire - $60.00 Power Pure 2CT 120/70ZR17
Rear tire - $110.00 Power Pure 2CT 180/55ZR17
Rear wheel - $175.00
Sprocket - $65.00 Like new 689 Miles on them
Chain - $35.00 Like new 689 Miles on them
Frame sliders (Motivation)- $75.00
Front rotor - $120.00 for both
Rear rotor - $45.00
Passenger pegs - $35.00
Swing arm w/Shock - $140.00
Battery - $25.00
Lower inner faring - $18.00
Right inner faring - $15.00
Left inner faring - $15.00
Center inner faring - $18.00
Right inner cover - $20.00
Left inner cover - $20.00
Frame - $1,100 Comes with Clean tittle. No cracks/dings. In perfect Shape
Sub frame - $100.00
Radiator coolant overflow tank - $15.00
Starter - $50.00
Rear Master Cylinder - $55.00
Front Master Cylinder - $100.00
Front Break Lines - $15.00
Chain Guard - $15.00
Rear Calipers - $35.00
Starter Relay - $20.00
ECU - $100.00
Wiring Harness - $100.00
Air Box W/Top Injectors - $45.00
Large Exhaust Heat Shield - $30.00
Air Intake OEM Center part - $45.00
Kill Switch - $29.99
Light Switch - $35.00
Fall Down Sensor x2 - $26.00 Per
Regular Rectifier - $35.00
Stock Headers - $29.99
Spark plug Ingition coils - $29.99
Battery Box - $15.00
Undertail Battery Tray - $30.00
Oil pan - $45.00
Clutch Cover - $20.00
Sprocket Cover - $12.00
Oil Pan Strainer - $15.00
OEM Nissin Front Break Calipers(Both) - $85.00
Valve Cover - $20.00
shoot me a pm if you're interested in anything.
1 - 1 of 1 Posts
