Hello everyone! So my wife and I just bought a 2008 gsxr 600 with 10,000 miles on it. When we bought the bike I of course rode it around the neighborhood and made sure there were no ticks, clutch flet good and it shifted like it was supposed to. Never really got on the bike till I got it home. The bike runs great other than around 8 to 9,000 rpms it face plants and throws the fi light. So I pull it back in the shop and try to pull the code but their isn't one. It says c00. The bike is stock other than a Yoshimura slip on which someone took the can off the end so it comes out of the header makes a loop of sorts and comes right out behind the rearset. Any ideas of why the bike is throwing the fi light? My wife and I work on our own bikes so any help would be very much appreciated. Thanks y'all!!!
Wheel Tire Vehicle Automotive tire Automotive design
I would suggest that you put some pipes on it that at least resembles a real muffler for starters.
That would at least make it less obnoxious and might actually fix the problem.
Also check the air filter/intake.
Might also want to check the pressure sensor for the fule pump and the filters in the pump....although most are non replacable. I would also run some FI cleaner through it....you never know it might just be a partialy blocked injector.
