The beams on low and high needs to be raised. I have followed the instructions in the manual, but turning either allen head to make adjustments up, down, left or right have zero effect. I tried loosening both screws and moving the inner bezel...still nothing. Any ideas? Thanks.
Yes, it is stock. Got it from a close friend with very low miles. He's not the modding type.
Looking at your headlight from the front, there are two slots at the 4 and 8 o'clock positions on the headlight bucket. The right one is for up/down, the left is for right/left aiming. You will need a number 1 phillips screwdriver. There is an adjustment screw inside the bucket at about a 30 degree angle. If you get down on your knees and look up into it you can see the head. Turn clockwise to raise and counter-clockwise to lower. The allen head capscrews on the ring are mounting hardware only.
