2015 YAMAHA SR400 – Full Spec Sheet
SPECIFICATIONS
2015 Yamaha SR400
ENGINE TYPE: air-cooled single, 2 valves per cylinder
DISPLACEMENT: 399cc
BORE x STROKE: 97.0 x 62.7mm
COMPRESSION RATIO: 8.5:1
POWER: not available
TORQUE: not available
FUEL INJECTION: EFI
TRANSMISSION
GEARBOX: 5-speed
FINAL DRIVE: Chain
CLUTCH: Wet, multiplate clutch
CHASSIS
FRAME: double-cradle steel frame
WHEELBASE: 55.5 in.
RAKE: 27°
TRAIL: 4.4 in.
FRONT SUSPENSION: telescopic fork
FRONT WHEEL TRAVEL: 5.9 in.
REAR SUSPENSION: swingarm
REAR WHEEL TRAVEL: 4.1 in.
FRONT TIRE : 90/100-18M/C 54S
REAR TIRE: 110/90-18M/C 61S
FRONT BRAKE: 268mm single disc
REAR BRAKE: 150mm drum
FUEL TANK CAPACITY: 3.2 gal.
WET WEIGHT: 384 lb.
SEAT HEIGHT: 30.9 in.
HEIGHT: 43.1 in.
LENGTH: 82.1 in.
