Hi there,
I have a 2016 Suzuki S40 Boulevard. I was riding one day and my bike just completely shut off.. No power/electrical! I tested the battery and it reads 12v. I purchased the Battery maybe 4 months ago.
My troubleshooting so far:
Removed the seat and checked the relay Fuse box and found that the 15v fuse blew. I replaced it. As I turned the key to on; I heard a slight pop. Checked the fuse again and noticed it blew as well.
I proceeded to remove the tank to check if there are any loose wiring etc but nothing!
Could it be that I need to check wiring along side the fuse box?
Please help!
Mahalo
Marina
Reply
Not enough information.
First, it likely is a 15 AMP fuse and you need to find out what that fuse feeds.
Not likely significant at this point but a 12 V AGM battery will read about 12.8 V when fully charged and 12.0 volts is a bit below half discharged.
When the engine is running, it should be charging at a bit over 13 volts.
I had the same problem. Turned out the compression release was crimping the wire from the solenoid when I hit the starter
