007 said:
Bandits are weird bikes - they are heavy, and they have a cruising seat - yet, they have a lot of torque and power, and they come with a 6 speed gear box. Go figure! :wink:
The specs on Suzuki's site says that the Bandit 1200s has only 5 gears. Do the older Bandits come with 6?
Specs
Engine: 1157cc, four-stroke, 4-cylinder, DOHC 16 valve, air/oil cooled with TSCC
Bore Stroke: 79.0 x 59.0 mm
Compression Ratio: 9.5:1
Fuel System: Mikuni BSR36
Lubrication: Wet sump
Ignition: Digital/Transistorized
Transmission: 5-speed
Final Drive: #530 chain
Overall Length: 2070 mm (81.5 in.)
Overall Width: 765 mm (30.1 in.)
Overall Height: 1220 mm (48.0 in.)
Seat Height: 790 mm (31.1 in.)
Ground Clearance: 130 mm (5.1 in.)
Wheelbase: 1430 mm (56.3 in.)
Dry Weight: 220 kg (485 lbs.)
Suspension Front: Telescopic, oil damped, preload adjustable
Suspension Rear: Link-type suspension, 7-way adjustable preload, 4-way adjustable rebound
Brakes Front: Dual hydraulic disc
Brakes Rear: Single hydraulic disc
Tires Front: 120/70 ZR17
Tires Rear: 180/55 ZR17
Fuel Tank Capacity: 20.0 liter (5.3 gal.) 19.0 liter (5.0 gal) CA model
Color: Gray, Blue
