Hey guys. I recently got a killer deal on an old bike. I originally thought it was a 68 KT120 trail, with the heel shifter and 3x2speed trans. Its not though...
The metal info plate on the back right part of the frame shows this info:
Model: B105P
Capacity: 118cc
Weight: 92kg
E. No: XXXXX
F. No: YYYYY
Stamped on the engine casing is: B100 XXXXX
Stamped on the frame is: B100 YYYYY
So now I know the model is B105P. Does anybody know what year this bike is? Theres no VIN # on it, so I don't know for sure. The only matching pic I could find is:
http://www.suzukicycles.org/photos/B/B105/1967_B105P_bw-left_800.jpg
That looks exactly like it, so I'm guessing its a 67, but does anybody know for sure? I'd just like to know the exact year.
Also can anybody tell me how the gearing works? The bike has a 4-spd trans, neutral at the top, and four gears going down. On the rear wheel there is 2 sprockets, a large one and a small one, like a mountain bike. How is this meant to be shifted? Is it just meant to loosen the rear end and move the chain to whichever sprocket you want to use, and then adjust the chain tightness? I guess its a cool idea, but kind of a pain in the *** if thats the case. Which rear sprocket would I want to leave it on for speed and street riding? Its currently on the large one.
Also, did this thing originally have a battery? I haven't seen a battery box anywhere, or a place for one. There is unterminated leads on the wiring harness, and I know this thing had lights, so I'm assuming they're for the headlight, but did it have turn signals or a brake light?
And finally, It has the oil injection system, but it has not been used. The oil line is still running from the oil tank to the engine case. I have been using premix in it so far. I want to start using the oil injection, or "Posi-Force Lubrication" as its called. What kind/weight of oil should I use in it, and how much? If I use the injection do I need to drain all the engine oil in it right now? How much oil does the engine hold, so I can change it if I just keep using premix?
Other than that, any information whatsoever is appreciated. The bike is really cool, runs GREAT and shifts perfect. I'm cleaning it up and just gonna use it for a fun little bike in the desert i think. I'm also looking for parts for it if anybody's got anything.
I need:
front fender, rear fender, headlight & gauges/speedo, front forks, rear shocks, chrome carb cover, rear luggage rack, brake light, turn signals.
Thanks so much for the help!!!!!!!!!!!!
Evan
[email protected]
If I can get some good info about this bike, I'll make a good webpage for all the info for other people who need help with this model.
Model: B105P
Capacity: 118cc
Weight: 92kg
E. No: XXXXX
F. No: YYYYY
I need:
Evan
[email protected]
