I was given a 79 Suzuki GS750E. It ran but not very well. Took carbs off to clean, noted the needle screws under the carbs (3 of the 4) were broken off inside the carbs. They are now garbage. I purchased used 750E carbs on ebay from a bike was claimed to have that worked but was parted out. I used a installed a (all 4 carbs) Suzuki carb rebuild kit, set all the needle screws the same number of turns as I found them. The idle worked well, rpm up to about 5k was ok then it bogged down, no power. I adjusted the screws (under the carbs) 1/2 turn out at a time, now about 1 turn out. The screws on the upper side of the carbs are set at 2-1/2 out as per the service manual. The manual states not to touch the needle screws under the carbs. Tough to do when rebuilding the carbs. The float levels are with .5mm of factory setting. Engine runs ok but not great. Any have any suggestions on setting the carbs up. Please help. Thanks.
