I am looking for some carb help on my 83 GS550L. I have the model equiped with the BSW30SS Carbs.The help i am looking for is i have two screws that seem to be air adjustment screws of some type on the front of the carbs on the outsides of the choke valve.Is that what they are ? If so or not what are they and what should they be adjusted to such as how many turns out from being turned all the way in ? All the help would be appreciated...Thanks.
Also i have attached a Schematic of the carbs on my cycle..If you look you can see the two holes on the front on the outsides of the choke plunger i am talkin(typin) about...
my 85 is only running if i leave the choke 3/4 close if i open the choke completely it will die unless i keep reving, adjusting the idle screw didnt do anything, it will idle a few seconds and slowly die, i think i might have to have this carbs rebuild by a real mechanic, my mechanic skylls just give me a slap on the face lol.
