Ihello I got a 91 katana it's got a strange 10 speed noise coming from the middle of the motor from behind the pipes you can only read here at real good in the front so I don't know it's I'm I'm whipped is there anybody out there that knows thank you
馃槶馃槶馃槶馃槶
Welcome.
I wish someone here.....or in another forum.......could help you but it's almost impossible to give even a good guess without actually hearing the noise.
Could be an exhaust leak. Could be a worn timing chain.....if it has one.
An independent bike shop might be able to help you out.
Could be the auto tensioner is about to click over to take up the cam chain slack. If it doesnt go away you may need to remove the tensioner to check how much adjustment is left. Often people put a manual after market one on...usually an APE tensioner. I do not like this path as it means a chain near the end of adjustment is being further used. Another less problematic issue could be a very dry/worn chain...the noise generated by this can sound terrible. A good chain lube may help the noise to subside and it will give an indication that this is the problem.
