My GSXR600(carb) is not running good. It runs good except when I give it throttle really fast, it stumbles, or hesitates. It also hesitates when I shift up. If I shift really fast it seems to be minimal. When I accellerate slowly there is no problem. It has 9700 miles on it. It is stock except for a D&D slip on and a K&N air filter(factory style). I took the carbs off and opened one up, it looked REALLY clean. There is a little Valve niose, but it has been there for a long time, and it just recently started acting up. I had a mechanic at the dealer listen to it and he said it wasn't bad. I changed the spark plugs, installed the new K&N air filter, and it seemed to get worse. Can someone please help me?
Has the bike been set up to suit the end can and filter?
Stevie called it, you need a jet kit. You've seriously modded the air flow and it sounds like you are running lean. Start there, even if thats not the problem its a must since you've modded the intake as well as the exhaust.
