My GSXR has a loose rod where a bearing is missing. It's caused damage to the Crank Shaft.
I was thinking about getting another CrankShaft and replacing it and putting a new bearing on the rod. Would this probably fix the problem? I asked the mechanic and he said "that'd fix it, but good luck finding one!"
I found a '98 (which supposed to fit the '99 also) crank shaft.
I'd rather try this solution out instead of buying a used motor for $1,000 - $1,500, then pay $500 in labor just to drop it in.
Should i go the cheap route and hope for the best? THe rod has NOT thrown, and the mechanic said there was only damage to the crankshaft.
It's making a clicking/clacking noise and is still drivable (but i'm not driving it).
