Hi, I'm new to the Forum, I ride a VTR1000 (hence the user name) but also a 2000 Bandit 1200 amongst other things.
The bike has done 20,000 miles now, and at first a light ticking noise appeared from around the final drive sprocket. Almost like a playing card placed in bicycle spokes.
The noise has got worse over the last 500 miles. Chain seems fine (no tight or damaged links) and trension is correct.
The clicking / knocking is most pronounced at low road speeds (less than 40mph) particularly when pulling out of low speed, very tight bends. If I put my left boot tight against the engine I can feel the knocking.
Over 40mph, it seems to smooth out and disappear (although wind noise then would make the noise harder to hear. so maybe it is still there.
I've just got back from a tour, and have not had chance to have a proper look yet. I wouldn't normally carry on riding with a noise like this - but I didn't really have much choice as I was leading a group of customers.
I've almost ruled out the drive chain, I need to check to see if the final drive sprocket has come loose, or is damaged / worn in some way.
Someone suggested it would be the bearing holding the final drive shaft (on which the final drive sprocket is mounted).
Before I start stripping it apart, does anyone have any tips or suggestions? Has this happened to anyone else?
If it's that bearing, can it be changed with engine in situ? How do I get the bearing out? Sorry - these things might be obvious when I get inside, but I haven't taken the cover off yet and just want some pointers if anyone else has had this problem
