I have a 20112 Suzuki Boulevard. Runs great but has a bit of a battery drain. I just put in a new battery a couple weeks ago. It's dead now. Question: Can I install a battery cut off switch on my bike utilizing a battery disconnect relay attached to the battery? I also would need to attach one side to the starter relay as I did in my pick-up truck. Can I do this and where is this relay located? My battery is located under my seat, so it is a pain to get to all the time. Thanks.
First, you need to have your new battery fully charged and then tested.
Just because it is new does not necessarily mean that it hasn't failed.
Did you charge it up before installing it ? That is important.
While it's not impossible that you have a "phantom" drain while off, that almost never happens unless you have something like an after-market alarm installed.
If you don't ride very often, using an automatic tender type charger is a better solution.
You can install a "pig tail" on the battery and bring it to the outside where it is easy to plug in.
