Hi all. Have a Gsxs1000fal6 with standard brake lines.
Will I be able to install 2 brake lines direct from master cylinder to each front caliper independently, as I think this will give me a better response from brakes. Suggestions welcomed thanks
Geordie
Geordie
I think that would be a HUGE waste of time and money, especially if it is an ABS model.
"stiffer" standard brake lines should be fairly easy to find and install. They "balloon" less when pressure is applied.
BUT.....unless you are racing, there really is no need to "upgrade" anything with the brakes.
If you apply them in "panic mode" now with the stock equipment, it is likely you can lock up the wheels........and there is no need to lock them a few milliseconds earlier.
