I would also emphasize the INSPECTION part.... When you're buying a used bike, unless it's from a DEALER (not to be confused with consignment shops), make sure you know what your state inspections guidelines are. Most modifications that are done on bikes DO NOT PASS inspection. Then you've got this great ride, and you have to go do all these changes back to stock this and stock that, JUST to pass, and then go back and replace it all again. All in all costing more $$$. (Remember: They don't tell you that you've failed until AFTER you've paid their fee).
HINT: Inspection guidelines usually are = to what your bike comes with and looks like as stock.
Then too, there is the alternative options of either greasing palms for an inspection certificate, or going through the hassle of finding a shop that will slide you through as long as everything is in proper working order. Either way, more $$$ to fork up again.
Helpful Tip: Some service shops will tell you what they look for if you CALL BEFORE you actually bring the bike in.
Check for requirements on your chain/guard, signals, windscreens, tires, etc. Case in Point - In MD, only CLEAR windscreens are legal BUT they're not required. So if you have say a Smoke windscreen (like me), all you need to do to pass that part of the inspection is take it off your bike. Stupid, I know, but most of these inspection requirements are a little overboard anyway.
