1 - 12 of 12 Posts
Banned
I had a 2003 Vulcan, and traded it in on my new 2007 C50T. With the Vulcan, I was able to cross-reference oil filters that were larger than the stock one, and used them. Does anyone know what other oil filters are compatible with the bike? Example, the Vulcan I had used a OEM # 16097-1072, I was able to use auto filters like so:
OEM Size
AC Delco PF2135
AMSOil SMF103
Carquest 85358
FRAM PH6017A
Honda 15410-MCJ-000
K&N KN-204, about $13. Metric nut on end for easy removal.
NAPA Gold 1358
Purolator ML16817. Imported, not made by Purolator.
STP SMO 17
WIX 51358
About 2.5 inches long
Purolator Pure One PL14612, about $6.
Mobil M1-108, about $12 - Made by Champion.
Bosch 3300, about $6 - Made by Champion.
About 3.25 inches long
Purolator Pure One PL14610, about $6 (This is the one I Use!)
Mobil 1 M1-110, about $10 Made by Champion.
Bosch 3323, about $6 - Made By Champion.
WalMart SuperTech ST7317 - about $2. Made by Champion.
So, I used the 3.25 inch fiters and only had to change the oil once every season. IS there such a chart for the C50T?
Banned
that chart looks VERY familiar
i think you can use the same filter, no?
I have no idea, which is why I asked. The motors are not the same, the KAW -vs- the SUZ. My uncle has the last run-year of the volusia, and his motor looks just like the Vulcan motor. The newer bikes, the motors look different.
ya, but oil filter mountings aren't THAT much all over the place.
go to the WIX filters page, and they have motorbike applications. you can then check specs of the kawi and suzy filters and see if the thread / diameter are the same
edit
hang on, i'll find that page and check it out for ya
Banned
Discussion Starter #7 (Edited)
Ok, the Vulcan threads are 20X1.5 MM, and the C50T is 20x1.0, so the chart I have, none of those filters will work.
SO I need a compatible, longer, filter with these specs:
Thread: 20x1.0 MM
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Burst Pressure-PSI: 250
Max Flow Rate: 9-11
Nominal Micro Rating: 13
The OE filter is almost 3"...
Anyone using Synthetic oil in their engine?
doh! you're right - i'm blind. :p
sorry!
ya, diff thread pitch. hmm.... i wish WIX had a table / chart of all their oil filters with specs, so that you could choose a filter based on certain stuff...
I took the All Bran Challenge
Suzuki OEM 16510-06B01
Napa Gold 1359
STP SMO 18
Bike Master 314-0025
Cycle Power 314-1919
Fram 314-6018 (PH6018)
Purolator ML6818
NAOA GOLD 1359
ProPart 01-0029
Emgo 10-55660 or 10-55670
VESRAH Sf -3007
JC Whitney Black -06AD3165B
Chrome-06AD3166P
WIX 51359
I copied this from an old list I carry in with my insurance papers.
Oil 10W-40 3.6 qts
Gear Oil SAE90-GL5-Mobil Synthetic
Gear Oil 6.8 to 7.4 oz
Coolant-50/50 Compat. with Aluminum Rad.
Rad. Coolant 1.6pts water 1.6pts coolant
Tire pressure Front 29 Rear 36
Tire Size-Front 130/90-16 67H Rear 170/80-15 77H
Tires IRC-Front GS-23F- Rear GS-23R (Tube Tires)
Spark Plugs-NKG DPR7EA-9(std)
NKG DPR8EA-9
Denso X22EPR-U9
Denso X24EPR-U9
Gap 0.8mm-0.9mm/0.031-0.035in
I hope some one else will check these as this is off an old list I carry.
While there is nothing wrong with using a larger filter, two things come to mind. You will, of course, need slightly more that the standard amount of oil to fill the system properly. AND The filter does not remove ALL of the bad things that accumulate in the oil so you should not go past the recommended change interval (you didn't mention how many miles you ride in that "season") just because of the larger filter. A larger filter will NOT prolong the useful life of the oil.:shock:
IMHO, however, the use of a larger filter is more trouble than it is worth. Unless there is something SERIOUSLY wrong with the bike, there is about 500% overkill already in the stock filter. There is more than enough filter capacity to handle any normal amount of crud. Most recommend changing the filter every other oil change. For more piece of mind, change the filter every oil change (I suspect most folks do that).
Sure, lots of folks do. The smart ones make sure that it is "motorcycle specific" synthetic.
Banned
Discussion Starter #11
I used the longer filters mainly for just the added bit of cooling surface. When I used the stock filter on the vulcan, the cooling fan came on more often than with the longer filter. I change the oil and filter every season, no matter how many miles I ride from year to year, I just change it every 1st riding day of the year. You sometimes get more volume with a larger filter, and more oil in the system means cleaner oil in the long run, but, no matter, I change it every year. I might put 2000 miles a year on it.
I bought an oil filter adapter for using automobile oil filters on my C50T.
Check out this site.
1 - 12 of 12 Posts
