Hello! My 800 has lost compression on both cylenders at the same time. It happend all the sudden and not over time. I was wondering if their is an easy way to see if the cams are turning over? Any help would be appreciated!
In general......remove the "valve covers" and see what if anything is happening when the engine turns over.
Might be a broken timing chain.
Thank you for replying. I will remove both valve covers. Now both cylenders have very low compression at the same time. If both chains are not moving what would I look for next? Bad sprocket on the crank?
Yes, something like that.
Is it possible that the cam timing for both cylinders is accomplished with only ONE timing chain loop ?
I really don't know but it certainly seems possible.
It has one chain per cylender so I assume they both are on a duel sprocket on the crank. I'm going to look it up. I'll let you know, and thank you so much for your input.
