My back light isn't working on my Maruader GZ 125, I have been trying to take out the light but I can't get it out I removed 2 screws the light comes out about 2cm but there is somthink stopping it form coming out still. Anyone know what i have to do?
Thanks.
On most bikes, you do NOT remove the bulb socket but instead remove the colored plastic lens.......which exposes the bulb quite nicely.
The lens is usually held on with two small, long skinny screws.
If that's the case with yours, just be careful NOT to overtighten when putting the screws back in.
The lens is fairly easy to crack.
Look under the lense mount to see if you have one screw holding it. On our M's that's what you remove and then turn the lense and pull out.
The microfiche looks pretty simple- remove the screw(s) and then pull it free, twisting the socket to free it from the lense once ou can get your hand in there.
CLICK TO ENLARGE
