does anyone know i can get a video showing the rejetting procedure on a 1999 magna v45, cant find anything on you tube
Is the intake/air filter and the exhaust stock ?
Either way, a healthy dose of Berrymans B12 Chemtool in the gas for a few runs might help.
Usually a "rejett" doesn't accomplish anything useful unless something else has changed.
Companies don't usually build engines with "hidden" power that can be retrieved with just a carb change.
I have no idea what you are referring to.
That number means nothing by itself.
And typically the "pilot jet" is NOT adjustable......except for the "air screw" that goes along with it.
The point I was trying to make with the first post is:
Unless some modifications were made, you do NOT "adjust" your way out of a fuel mixture problem.
You need to find out what is causing the lean condition and FIX it.
The stumbling could be due to the carbs being out of sync. I would be doing a carb syncronisation before messing around with jets. Also the floats must all be to spec....any that are out will starve or overfuel the cylinder it feeds.
