Turn the round adjuster on the lever perch all the way in to the perch. Then go to the clutch side of the motor and you will see the threaded adjuster with 2 12mm nuts. Losen the nuts and turn the threaded part until you take up all but the last 1/4 inch of play at the clutch lever on the bar.
