1 - 7 of 7 Posts
HI EVERYONE.NEW TO THIS FORUM AND LOOKING FORWARD TO EXCHANGE INFO WITH U ALL.ANYONE WITH A O4 GSXR 600 MIGHT BE ABLE TO HELP ME OUT.I HAVE A PROBLEM WITH FIRST GEAR WHEN IT SEEMS TO GET STUCK OR SOMETHING AND WON'T LET ME GET IT INTO FIRST GEAR. :?:THIS HAPPENS ONLY ONCE IN A WHILE.BUT BUGS ME.
//It'll shift slicker with synthetic oil. Also, put downward pressure on it, slowly let out on the clutch and it'll pop into gear before you fully let out.
//May want to find the capslock button on the PC
98G
are you comming to a complete stop and then shift all the way down to first again. Sometimes if I do that when I stop quick I have to let the clutch out just a little just before it grabs and then close it, then I first right into first, I think it is a common thing if you are trying to shift all the way through the gears in a stop.
That just what I have experienced with my adventures.
Also try downshifting why slowing then you will definitely not have that problem
IS THAT YOUR FIRST BIKE????????????ALSO DID YOU TAKE THE MSF COURSE??? OR WERE YOU SELF TAULT???
I have an 04 GSXR 600 too.
I noticed if I am decelerating and shifting from 2nd to 1st I sometimes pop it into neutral accidently. From there I kinda have to push harder than usual to downshift and it goes into gear kinda hard. I realize to just shift more with your toe and the gears roll more smoothly.
If youre stopped and in neutral, sometimes the bike won't go into gear unless you roll forward/backward an inch of so. It can sometimes be between the mesh in the gears. This usually happens when I start the bike up when I parked on a hill and left the bike in gear.
Discussion Starter · #6 ·
thank u for ur great informations and i must have to agree with memphis here.tried it and it hasn't been happening.guess i can't get to lazy with downshifting.and yes novaz this is my bike and i self taught my self how to ride with all my friends bikes over the years starting 8th grade.and joydog where are u located.thanks for ur info 98g
No offense but maybe you should take a MSF beginners rider course im sure it will help since you are fairly new to riding.From what i learned from this site even the veterans would recommend you take that course.
1 - 7 of 7 Posts
