Dearest mechanic friends please help!
Bike is a 1999 Honda CB250 and I love it to death. The clutch was shitty when I bought the bike (gear changes really clunky on the pedal and won't shift into neutral if the engine is running - really unhelpful when I'm stopped at a red light and realised I haven't done my helmet up!).
So I finally decided to put new clutch plates in and now the gear pedal is smooth and delicious. I replaced the clutch cable too because the old one was stretched and worn. Put it all back together, new oil in, adjusted the new cable all to manual specs. No worries. Started it up in neutral, clutch in, put it in first and the bike shot forward and stalled. First I assumed I didn't set up the new cable correctly and the clutch wasn't engaging/disengaging properly. But after much adjusting, I don't believe that's the case.
So I drained the oil, took the crank case cover off again and had a look. I suspected I didn't do the lock nut up tightly enough, so I went to tighten it. When I previously undid and redid this nut, I depressed the rear brake first otherwise the rear wheel would just spin with my tightening. But now, when I depress the brake, the clutch spins as I try tighten it.
I haven't touched the rear wheel or brakes at all since I've done this work.
What the heck?!
Can someone please shed some light on what I've done wrong here? Desperately missing riding my moto
thanks in advance
What the heck?!
