I have a 2002 sv650s that I would like to convert naked. Any suggestions on lights, brackets, etc. Or any problems that i might be facing.
you will need new cables as the naked bars are taller unless you keep the clipons then it's fine.
Why are you wanting to change?
Im going to keep my bars and such. I just want the naked look i Like it much better.
I was just wondering if anyone knew where to get a an aftermarket bracket to hold my speedo and odometer and things like that. and what different light options i have.
Buell lighting and wind screens are popular as far as speedo a lot of people go with the vapor speedo to fix the no bracket problem. I would just make a bracket using the threaded holes in the neck then you can mound them to fit you headlight option.
I am toying with the idea of converting my N to an S as I have not seen a naked configuration that looked better than the S
