· Site Admin & Squeegee Boy
Ratio can be anything from about 20/1 to 40/1 usually recommend middle ground 30/1. Depends on how you ride the bike, flat out crazy riding for long periods go with the higher ratio ( more oil ), relaxed backcountry cruising go for lower ratio ( less oil ).
If everything in the engine is ok and it still smokes a lot reduce the oil.
I recommend Amsoil 2 stroke oil (if you can find it). When in doubt I mix everything to 32:1. Always with premium fuel. two-strokes seem to run a lot better with premium. Good gas and oil, and mixed properly, can make all the difference for how your bike runs.
I know everyone will tell you something different, but the factory recommends a 32:1 mixture with their brand of premix with 92 octane gas. I have an '03 RM250 and run 40:1 with 92 octane and I use the Maxima Super M premix. Not much smoke and lubes well. Good Luck
