Valid Point!!!!
md2lgyk said:
You'd better check with the SPs first. At my base (Air National Guard) after 9/11, anybody with their sticker on a metal plate had it confiscated and replaced with one stuck to the bumper or windshield. The reason given was that the ones on metal plates are too easily stolen.
I have been out of the Navy since 1998,, but even then we had restrictions as to how the sticker had to be mounted. If you can get away with a metel plate that is great,, even a plastic one you could get some clear acrylic plastic and make a bolt on piece.
But the catch is every base has it's little quirks. At Mayport Naval Station we were required to have it attached to the front forks. If your forks are steel and a magnet will adhere to it try this......
go to a sign shop where they make magnetic signs,, they will sell you a piece of that thin magnetic background where you could trim it to the size of the sticker,, stick the sticker to it, and the magnet will stick to the forks. If you have aluminum housing then maybe you could some clear laminate or some hevy clear vinyl that you could tie wrap from the rear and then it will appear that the sticker is stuck to the fork,, when ready to remove just snip the tie wraps.......Just a thought. :mrgreen:
