Hi guys. Thank you for using this forum. I have a Ducati ST4 ABS. I detached the cables from my 6 months old battery for charging. When i charged the battery.....the indicator showed 100% charged. Went to neighbour to re-check and results also 100% working and charged. When i attached the Pos and Neg cables to the battery, a ticking noise was heard in the speedo meter. The needle of the speedometer was fibrating very fast. I doesn't stop as long the battery is attached.
Are there some bike wizzards that have an idea what this could be?
Thank you
First, there is no reason to remove a battery to charge it.
Second, are you sure the cables are being reconnected to the proper posts ??
Then, what is the voltage reading at the battery when that happens ?
YOu can't ever be sure a battery is "100% working" until you actually put it into service.
Have you tried turning on the ignition.......assuming that the connection polarity is right ?
