Well after a fun weekend working on my bike....I found that some of the fairings need to be replaced.
I was wondering if fairings were inter-changeable....meaning....could I buy fairings from a 2001 katana 600 (I have a 94 katana 600).....and would they bolt up to my bike??
Just curious...because if I have to replace them anyway...y not give my bike a "newer" look.
Thanks in advance.
Sytrix said:
WOAH!! Thanks!! That link helped alot!!
I am going to order everything that I need from there now!!
THANKS!!! :D
I only saw two parts for the Katana there the front fender and the lower middle for the front cowl which joins the two side panels together, I did not see were you could order the side panels from..Did I miss somthing?
You still can have the old stuff repaired and painted, it may be cheaper than buying a complete set of plastic that still needs paint, check out my site and see if there is anything I can do to help..Bob
http://www.empiregp.com/
Discussion Starter · #7 ·
Shitty....you are right....there was only 2 katana parts on there....
Do the GSXR 600 plastics bolt up???
Also on your site I did not see anything for the katana....if there is can you point me in the right direction?
Thanks for the help :D
I dont' sell anything for the Katana either, I have plastic for over 60 bikes and none for and of the Kats, they must figure there is not enough demand to make it.
I can repair just about anything you have, I have damaged plastic that I can get parts from if you are missing plastic I also have some plastic laying around from some of my bikes that I could get rid of, Let me know what you need and let me know the extend of the damage and I do the best to take care of you..Bob
