Thanks for the reply easy rider but I didn't unplug the wires I only took loose from mounting bracket. I have checked the connection since finding the issue but still no help. I checked for voltage at connecters am not getting any reading at all
SIGH.
You do not have to "unplug" wires for the connection to come loose or become bad due to corrosion.
When you had the TO sensor loose you likely tipped it and triggered a "fall over" situation.
I don't know if it takes any special proceedure to clear that or not. Others may know.
As for the "no voltage" at the connectors, that depends on exactly WHICH connector wires you are looking at and what they do.
If two wires go to a switch that is normally closed, you might not normally see any voltage on either.
Did you try disconnecting the battery for a few minutes ??
You may need a shop manual or wiring diagram to figure this out.
The fact that it happened right after you had things apart probable is NOT just a coincidence.
It is possible that you blew a fuse. Have you checked them ?
