1 - 10 of 10 Posts
Hi,
Two questions regarding my Honda CGL 125 (Or 11hp beast as some refer to it :lol: )
Flat spot in third
When I change up into third, it dies ever so slightly - revs build up, then die down about two seconds then comes back then dies and comes back again, with me screaming various expletives at the bike. It runs on unleaded petrol.
Is my clutch stuffed?
It is becoming increasingly difficult to pull away on a hill, almost as though the clutch is slipping. And this morning, the clutch started clanking when released. Am I in trouble?
Regards
Dwayne Hicks
Hi dwayne,
psychobilly is right, i used to own a cg 125 (an old model anyway) and suffered the same problem regarding revs in 4th gear. It was due to a combination of a bit of water in the carbs plus a worn out battery. try draining the carbs first and if it still persists then try a different battery.
As far as the clutch goes clanking is never good take the right side panel off the crank casing and have a look at the clutch plates (which should be visible) and check for damage and discolouration.
hope this helps you to find speed again,
Nige.
Thanks very much for your help guys. It probably could be the carbs - it has 2600 miles on it at the mo, and its about 800 miles past its service which never happened, which should have happened 800 miles ago. I plan to take it in before the end of Feb, providing the boss is gracious enough to give me time off.
Thanks
Dwayne
Discussion Starter · #8 ·
Yeah, but there was a free lunch involved! :lol:
Regards
Dwayne
Discussion Starter · #10 ·
Gone for its service now. Sounds much better, and performs better too. New problem now is the clutch has been adjusted, and the lever is almost fully released before the clutch disengages, which is annoying. I am going to get the manual this weekend and adjust the cable again.
Ta
Dwayne
1 - 10 of 10 Posts
