Not really. Forks are very straight forward to work on. Make sure you either get a fork seal driver, or use a long piece of PVC pipe to drive the seal in. Also check the parts diagrams for other parts that might need replacing (bushings etc.) You will also need a GOOD set of snap-ring pliers.Plus its a beotch to do.
